How do I engage my CDL?
Old Oct 20, 2007 | 06:09 PM
jkid's Avatar
Default How do I engage my CDL?
I'm pretty sure that my '01 has a CDL. I can feel a round plate with three bolts and a 3/4" threaded stud sticking up in the middle on the top of my TC. Should this be it? If so, I'd like to lock it so I can drive around without my front driveshaft whileI replace the u-joints (at my leasure). I don't really want to go at it with a pair of pliers, but I can't see what's up there.Whatshould I use toturn it, and should it turn pretty freely? Is there any reason that I shouldn't drive it around while locked up? Thanks.
Old Oct 20, 2007 | 06:40 PM
xb70valkarye's Avatar
Default RE: How do I engage my CDL?
That is it! It should turn pretty esay especially is you have the trans in neutral and lift one of the front wheels off the ground and turn it a little as you rotate it with a pair of pliers. When that wheel stops turning you know it is locked. I took it a step further on mine and bought the linkage from a Series I at a junk yard and bolted it on. Now I can engage it whenever I want. Best of luck.
Old Oct 20, 2007 | 07:08 PM
okdiscoguy's Avatar
so you know, This is what it looks like from the top.....
[IMG]local://upfiles/5440/9C35FC4709C3442891BA55CAF2049296.jpg[/IMG]
jkid's Avatar
Got it, thanks. How does the lever connect when it's installed?(out of curiousity, does the lever run up into the cab somehow or do you reach underneath).It feels like there are threads there and I don't want tobugger them up with pliers.
Old Oct 20, 2007 | 07:10 PM
jkid's Avatar
ORIGINAL: okdiscoguy
Thanks! that clears it up. Looks like it sits on there and is clamped down with a nut.
Old Oct 20, 2007 | 07:45 PM
okdiscoguy's Avatar
if you go to www.discoweb.org, click on the tech tab, and find the CDL link. YOu can get a solenoid kit from www.greatbasinrovers.com. just hit a button on the dash, and you are in...
Old Oct 20, 2007 | 09:33 PM
Fonzie's Avatar
I found another conversion kit that uses cable operated system from the 2004,instead of hard linkages. Apparently hard linkages can add to noise and vibration inside the cabin. It's a slick looking kit that even includes a new oem cdl t-case shifter ****. A bit spendy though: (scroll down almost half way) https://www.expeditionexchange.com/discovery/
03discoman
May 25, 2010 08:02 AM
DavidG
Aug 31, 2009 06:36 PM
unstable
Apr 29, 2008 07:15 PM
02Disc02
Apr 22, 2008 10:09 AM
R_Lefebvre
Jan 23, 2008 07:49 PM
