How do I tell if I have premium stereo
Old Feb 27, 2015 | 05:09 PM
Jnj's Avatar
Jnj
Default How do I tell if I have premium stereo
2001 disco. Two options normal sound system stock or Harmon kardon? Need to get a wire harness for an aftermarket unit
Old Feb 27, 2015 | 05:14 PM
sdhow's Avatar
On my '03, it says Harmon/Kardon on the front door panel speakers. Or you could remove the rear subwoofer and look at the sticker on the subwoofer box to see if it's a H/K unit.
Old Feb 27, 2015 | 05:27 PM
Jnj's Avatar
Jnj
Do all discos have the cd changer under passenger seat and subwoofer is rear tailgate?
Old Feb 27, 2015 | 05:36 PM
sdhow's Avatar
To my knowledge, yes. That is IF your car was optioned with the CD changer. I am unaware of the base S (SD on the pre '03 Disco IIs) model even being available with the premium stereo package. Both the SE and HSE had subwoofers in the rear tailgate door, whether they were standard or premium sound systems.
Old Feb 27, 2015 | 05:58 PM
Alex_M's Avatar
My '03 Disco S Model had neither. It was the HK system, atleast before I went through and replaced everything down to the speaker wire.
Old Feb 27, 2015 | 06:17 PM
Big Jim Swade's Avatar
I don't think the 2001 had a stereo that was branded as Harmon Kardon, it was just listed as the "Premium Stereo" for that year. I know that the speakers were branded as Phillips.
If you haven't read this post yet, it has a lot of good info in it.
https://landroverforums.com/forum/di...ey-come-53795/
Old Feb 27, 2015 | 06:36 PM
Jnj's Avatar
Jnj
I have read that before.
I'm just trying to figure out if I have premium system or normal as the aftermarket wire harness for either has different part numbers.
Old Feb 27, 2015 | 06:46 PM
lordmorpheus's Avatar
Does the standard system have the "Spacial" option on the head unit? (That was not a misspelling of special)
Old Feb 27, 2015 | 07:58 PM
Jnj's Avatar
Jnj
I don't even know what that is lol
Old Feb 28, 2015 | 04:08 PM
Jnj's Avatar
Jnj
Ok took my stock alpine head unit out. On the back there is three plugs. Bottom two rows connect to the metra harness, is the top row of two smaller plugs for steering wheel control? I'm not trying to keep the controls so if I run the bottom two plugs of factory harness I'll be good??
