How to drop the fuel tank in 2003 Discovery 2?
Old Aug 6, 2022 | 11:00 AM
kevinn's Avatar
Question How to drop the fuel tank in 2003 Discovery 2?
Hey everyone, I'm finally removing my fuel tank to get some room to weld up my rusted out frame in the back.
  • I've got the harness + fuel line disconnected via the trunk
  • Disconnected the filler hose & breather hose
  • Removed the left side of the tow bar
You can see there's still a bolt "in the way" in this shot but the fuel tank never gets low enough to even touch it. But I don't see what's blocking it. Should I just yank it down now? Which side / corner should I pull down from?
Thanks!!
I know what you're thinking, "Why bother? That frame is perfectly fine!"
Old Aug 6, 2022 | 11:33 AM
zski128's Avatar
I just dropped my fuel tank. I had to remove both tow hitch bars and you will need to pop that bolt out. Pull down from the drivers side, it will be a little tight but it will side right out.
Old Aug 6, 2022 | 12:36 PM
frostythor's Avatar
OK, but be aware there are 3 hoses on the filler side, the large filler No 22, a breather No 26and another No24, that has a plastic clip you need to squeze to get off, it abouve the filler hose onto the side of the body
Old Aug 7, 2022 | 10:39 AM
kevinn's Avatar
OK will give this a shot -- that bolt really doesn't want to come out (square wrench, socket, impact, PB plaster, butane torch) so I may need to go grab a propane torch, weld something to it or even cut it off. Good to know there's nothing else blocking it besides these items!
I will check for this. Mine is a North American and I think this is only on the non-NA models but at 20 years old and many owners who knows what parts have been mixed & matched!
Old Aug 7, 2022 | 11:09 AM
frostythor's Avatar
I did check both the V8, and TD5, tanks show the same hose configuration
vanbadri
Nov 13, 2022 10:29 AM
_Allegedly
Jun 22, 2022 12:46 AM
MTboggs
Apr 16, 2017 07:41 PM
gunsanroses91
Nov 23, 2013 09:29 AM
camrover
Defender
Jul 2, 2012 03:00 PM
