How to fix your window roller for 50 cents....
Old May 6, 2011 | 10:01 PM
malibutj's Avatar
Default How to fix your window roller for 50 cents....
I took two quarters and cut each out in the U shape that you see, with this method you don't need to drill anything out.
I just pushed two quarters with those shapes against themselves, the part you don't see is I put a copper plate up under the quarters and bent the corners of the copper so the quarters don't come apart.
Works great! Window fixed. 50 cents and an hour and a half.
Attached Thumbnails How to fix your window roller for 50 cents....-img_3895.jpg   How to fix your window roller for 50 cents....-img_3894.jpg   How to fix your window roller for 50 cents....-img_3893.jpg   How to fix your window roller for 50 cents....-img_3896.jpg   How to fix your window roller for 50 cents....-img_3897.jpg
Old May 6, 2011 | 10:13 PM
buick215's Avatar
Good write up and clever solution. On thing that I noticed is that the quarters don't roll like the plastic wheels they just slide back and forth, am I right or wrong.
Old May 6, 2011 | 10:22 PM
malibutj's Avatar
You're right, I just greased them up real good. When I did my test on it, the plastic rollers didn't roll either, they just slid back and forth. Thanks!
Old May 6, 2011 | 10:57 PM
buick215's Avatar
Yeah, you are right the plastic ones don't roll even though they are suppose to. That is probably why they have such a high failure rate.
LRD2&ME
May 23, 2021 07:57 PM
FieryRebel28
Nov 20, 2012 09:03 PM
bcolins
Mar 22, 2012 05:47 PM
hilltoppersx
Off Topic
Jan 6, 2010 05:52 PM
slave600
Oct 11, 2008 08:51 PM
