How I solved P1415 and P0174
Old Aug 25, 2014 | 06:08 PM
jasile's Avatar
Thumbs up How I solved P1415 and P0174
I got the following codes:
- P1415 code (P1415 Secondary Air Injection System – Malfunction Bank 2 RH)
- P0174 (System too lean (bank 2)
- P0150 O2 sensor circuit malfunction (bank 2, sensor 1)
I did some research about the codes on this and other LR forums and the RAVE. This seems like a pretty common problem so I thought I would share my remedy.
I isolated the problem to the bank2 SAI valve. I could not identify any vacuum leaks or clogged hoses. What I did find out was the sound the bank 1 SAI valve makes when it operates properly. I removed the bank2 valve and cleaned it out with a liberal amount of parts cleaner then reinstalled it. Applying vacuum to the newly cleaner valve (I wouldn't call it clean) I got the noise that the good valve was giving me. Apparently it was just a stuck valve. I cleared the codes and only the P0150 has returned...got a new O2 sensor on order.
Old Aug 25, 2014 | 08:36 PM
04duxlr's Avatar
Nice. Hope it holds for you. Glad to hear you got the valve off without breaking any bolts.
Old Aug 26, 2014 | 03:57 AM
austin_green1985's Avatar
Got same error with you, use Chinese JLR Mongoose v138 clear trouble code, but trouble returned yesterday, now follow your instruction, fix it. You are best, thank you!
Old Aug 26, 2014 | 06:59 AM
jasile's Avatar
04duxlr: the bolts were actually pretty easy. I didnt even need any liquid wrench like I did on the O2 sensor. If I had gotten to the valve sooner I might not have to change the O2 sensor.
millejdq
Jan 9, 2023 10:46 PM
Torancis_LR
Sep 27, 2015 01:23 PM
jallen9
May 8, 2013 12:24 AM
JEFIII
Sep 9, 2010 11:16 AM
JAC
Oct 28, 2009 04:47 PM
