How to know fuse box is bad
Old Apr 16, 2023 | 02:06 PM
cybercop's Avatar
Default How to know fuse box is bad
the truck is randomly shutting down and will not start afterwards. I will hear a clicking coming from the under hood fuse box. If I bang it with a hammer, the ticking will stop and I can crank the truck for a while.
I isolated it to R9 which I think controls the ecu. When it starts clicking and I bang it it will stop and let the truck start and run for a while. I went to Advanced Auto and we found a relay that matched the specifications, but it did not fix the issue. (Maybe not a good idea to get a non specific relay?)
I pulled the entire fuse box. Is there a way to tell a fuse box is bad?
Old Apr 17, 2023 | 03:21 PM
cybercop's Avatar
No advice on this? Everyone I am calling says they have had the fusebox on backorder for over 6 months.
Is there something to check on the fuse box and possibly repair?
Old Apr 17, 2023 | 04:20 PM
jastutte's Avatar
pull the fuse box and look for possible breaks in the solder.
have you checked all the relevant grounds to be sure there is no corrosion and/or rust?
intermittent electrical issues are bitch to find and fix.
Old Apr 19, 2023 | 01:03 PM
nashvegas's Avatar
Hint: before you mess with the fusebox replace that questionable R9 relay with a known good genuine LR one...
austinlandroverbill
Aug 2, 2021 07:44 AM
Abdel Elsawabi
Jul 25, 2017 12:15 PM
Dave Bristow
Feb 14, 2015 01:28 AM
LR03NJ
Jun 26, 2010 10:13 AM
ajh
May 8, 2010 08:15 PM
