How long until my service engine soon light shuts off?
Service engine soon appeared on my dash yesterday. I went to autozone and they told me it was an evap leak. I checked the gas cap and it was loose enough to remove without unscrewing. So I clamped it down until it clicked. I’m hoping this was the reason for the service light. How long should I drive the vehicle before expecting the light to shut off again? Aka when should I start looking for other problematic sources.
Buy your on ob2 tool you are going to need it anyway, you can delete codes and turn off your check engine light
https://www.google.com/search?source...76.tQs0BkQbxUY
I had a brand new 4Runner that I had the exact same thing. It took a few drives to go off. Late the next day I think. But like others have said you can use a diagtool to clear it. One of the best purchases I made for this vehicle to date.
It didn’t shut off after 1 week of having the gas cap tightened. I picked up a garden variety fuel cap and replaced the purge valve. I shut the light off with a plug in code reader today. Let’s see if it stays off.
P0455 code
P0455 code
bavarian_range89
Nov 1, 2007 08:33 PM
