How to make a cold air intake, by request.
Old Sep 25, 2015 | 02:18 PM
  #51
Alex_M's Avatar
Very nice looking, Jesse!
Old Sep 25, 2015 | 09:26 PM
  #52
jessezipper's Avatar
when i get time im gonna attempt with a heat gun, how hot that pipe gets and might just wrap it with header tape
Old Sep 25, 2015 | 10:02 PM
  #53
Alex_M's Avatar
When you do be sure to post back with results!
Old Sep 27, 2015 | 03:41 PM
  #54
OffroadFrance's Avatar
Originally Posted by Alex_M
I can't say that I have. The lady probably wouldn't be happy if I went looking up other women's a**es, but I'm sure you can enjoy it enough for the both of us.
That sounds very interesting, but why after the MAF instead of before? I'd be worried about that causing me to run slightly lean from the extra unmetered air. Very interesting idea though, can't wait to see what you make of it.
I've hit a setback snag Alex, manifold boost pressure I should have seen that one (amateur I hear everyone say) but I think I've got an answer .......................... maybe. I'll let you know how it works out otherwise hide somewhere with embarrassment
Old Sep 28, 2015 | 07:37 AM
  #55
Charlie_V's Avatar
I went through a phase when I was so active in the forum, I had to get away and do some remunerative work! Well, that's under control tool so here I am again. Just before I left last time I ordered an AEM dry filter that matched the specs of the one Alex is using andand, after three weeks it finally arrived on Saturday. Before I take everything apart to see if it will work, has there been any major evolution in the design?
Old Sep 28, 2015 | 07:32 PM
  #56
Joemamma1954's Avatar
Originally Posted by jessezipper
I like it, Jesse. I am worikkng on something like this.
Old Sep 29, 2015 | 09:55 AM
  #57
Alex_M's Avatar
None other than Jesse's heat shield which will make no difference in the design of the intake itself.
Old Sep 29, 2015 | 01:38 PM
  #58
WNYErikDiscoII's Avatar
Former Sponsor
This is a great write-up and performance mod, but any sort of water crossing, mud or dirt are completely out of the question with this in your engine bay.
Old Sep 29, 2015 | 01:50 PM
  #59
Alex_M's Avatar
I've actually not had any trouble with shallow water crossing (just touching the frame, no higher) or mud. I will be extending this to run out the quarter panel, up to the windshield, then up much like an actual snorkel. I first need to make some kind of hood for the filter itself since it will just be sitting on top of the snorkel, but once I get a rain hood and add a drycharger made up it should be no issue. As for the dirt, well, it does let more through no doubt. It will increase piston ring and cylinder wear somewhat, but the minimal change in contaminants entering the engine is something I'm fine with personally.
Old Sep 29, 2015 | 10:50 PM
  #60
Charlie_V's Avatar
The AEM 10009 does not fit. I'm going to make it fit. But it is about 1/4 inch too big for the MAF. (AS ALEX SAID!)
