How much play in the water pump?
As some of you may know we had an overheating issue and decided to put in a new rad as well as a new 180* t-stat and have had great results but, now I am chasing a ghost. We discovered a slight knocking sound coming from the front of the engine and decided to check the water pump first. As I move the pump via the pulley it has (imo) a lot of play but what is the tolerance? If you take a new pump should you be able to move the impeller up and down as well as in and out or is it very solid with little or no movement. I will try and take a video and see if that helps.
on
water pump free play
Agree fully with Mike. You should have no perceptible forward and backward play, and no side to side play at all that you can notice by feel. If you do, you should change it ASAP to avoid having it fail big time, and you will be up a familiar creek with no paddle. On my 2004 Disco II, with 80,000 miles, I have carefully checked for free play in my water pump, and have found none.
began
11-23-2008 08:59 AM
