How to remove the AC bracket shaft from the block
Old Feb 13, 2020 | 10:09 AM
Richard Gallant's Avatar
Default How to remove the AC bracket shaft from the block
As the title says how to get this thing out, the 2 bolt turn against each other system ? Long shaft in the image
Old Feb 13, 2020 | 10:18 AM
JUKE179r's Avatar
Double nut it?
Old Feb 13, 2020 | 10:33 AM
Sixpack577's Avatar
Originally Posted by JUKE179r
Double nut it?
+1
jam nut, one against the other, then you can turn it.
That, or heat it and use vice grips on the shank, away from threads.
Old Feb 13, 2020 | 10:52 AM
Thanks guys I will give a try at later today
Old Feb 13, 2020 | 10:54 AM
Discorama's Avatar
Stud remover. I used it for removing manifold studs. Worked like a charm, no damage on thread.
Old Feb 13, 2020 | 12:18 PM
mln01's Avatar
Why remove it? I think I left it in place when I did my head gaskets. Or do you need to move it to a different head?
Old Feb 13, 2020 | 12:27 PM
mollusc's Avatar
Pipe wrench should also work.
Old Feb 13, 2020 | 01:17 PM
@mln01 need to move it
Old Feb 13, 2020 | 03:02 PM
Thanks everyone 3 x 13mm nuts locked together and an hour of sitting with penetrating oil,before trying got it out nice and easy
Old Feb 13, 2020 | 07:01 PM
Extinct's Avatar
I take them off and never put it back. Makes it much easier to replace the power steering pump.
nmacej
Feb 28, 2018 10:57 AM
Chrjones
Sep 10, 2016 09:12 PM
jycsalas
Oct 27, 2011 08:23 PM
twaszak
Jun 4, 2011 09:01 AM
jnance50
Feb 18, 2010 09:19 AM
