How to Remove the Rear Jump Seats on a 2001 SE7?
Old Aug 25, 2018 | 11:17 PM
Papag1313's Avatar
Default How to Remove the Rear Jump Seats on a 2001 SE7?
I have searched the Forums here on how to remove the Rear Jump Seats on a SE7 and am very confused...…
The best post said:
"Lower the seats to access the mouting points. Remove the plastic covers by pulling off. You'll then need to remove the two bolts on the top of the pivot bracket and two nuts on the bottom of the bracket. Now just pull the seat assembly off the bottom studs and you done. Not sure I'll ever put mine back in...."
My question is, I've looked and looked and looked, but I can't find the Two Bolts on the Top and the Two Nuts on the Bottom....
Also, have searched YouTube, etc for videos with no luck.....
Can anyone point me to some clear instructions or a video on how to remove the Jump Seats as I have purchased used Cargo Bin interior parts to convert the rear to a more useful configuration for my needs.
Thanks in Advance for ANY help!!!!!
Old Aug 26, 2018 | 01:58 PM
Richard Gallant's Avatar
This is pretty easy, BUT use penetrating oil for a day ahead mine had red lock tite I snapped a bolt. Here is the Rave manual page re removal. I strongly recommend you down load the RAVE it will save you alot of time and headache
Old Aug 26, 2018 | 09:33 PM
Papag1313's Avatar
Thanks Richard!!!!!!!!
Once I saw the diagram you sent it was a breeze!
alphawolfman
Dec 7, 2011 09:39 AM
Buzz
Aug 17, 2011 12:10 PM
hunter
Jun 7, 2011 07:06 PM
Voyageur
Oct 22, 2010 10:26 PM
alpineclimber
Dec 16, 2009 08:35 AM
