How to switch to synthetic oil at the transmission?
Old Mar 29, 2008 | 11:28 PM
arteliare's Avatar
7th Gear
Default How to switch to synthetic oil at the transmission?
I will service '97 Disco transmission by changing the oil (not flushing)...I know that the current transmission oil is not synthetic....but I will be changing to synthetic....
1. Will the synthetic mix with the non-synthetic without causing problems to the transmission?
2. If yes, how often should I empty the oil pan of the transmission to pour more synthetic without causing problems to the transmission?....
Which one will you recommend the best.....Mobil 1 or Royal Purple?....
Old Mar 30, 2008 | 08:31 AM
Default RE: How to switch to synthetic oil at the transmission?
How many miles on your tranny?
If you are up over 100,000 miles, I wouldn't switch it, this could cause it to fail.
I believe you would be better of using some of Vavoline's Max-Dex for high mileage trannys and change the fluid every 15,000 miles, the end results would be better.
Old Mar 30, 2008 | 10:53 PM
arteliare's Avatar
7th Gear
122K on the transmission....I just bought it, the transmission change gears very nice and the oil does not look darks, nor smell burned, neither produces bubbles.....but since I do not know what kind of oil the transmission has, I do want to purge the old oil (by servicing periodically not by flushing).....will a bi-weekly service be too much?....by the way....how many gears does this transmission has....it seems to go from first to third.....and then fourth (or overdrive) at +-55mph....is this OK?....
bulldozer32
Jan 15, 2011 11:32 AM
bscmich
Jan 14, 2010 10:56 AM
muddybuddy
Jun 4, 2009 08:50 AM
herblatham
May 1, 2008 05:57 PM
GCS1
Aug 9, 2007 07:26 AM
