How thin is thin on the break pads?
Old Feb 7, 2008 | 01:20 AM
BADBUZzZzZz's Avatar
Default How thin is thin on the break pads?
With my wheels just right I can see thro and look at my break pads from 1/16 too 1' what is good how thick?
I have never done breaks befor should I try is it hard?
O) I have 03 disco hse 51,000 miles!!!!
Old Feb 7, 2008 | 07:42 AM
Default RE: How thin is thin on the break pads?
If your pads are thinner then the backing plates, they need to be replaced.
As to your doing the brakes, yes, if you want to save alot of money, I can walk you thru a brake job if you are at least somewhat mechanical.
Old Feb 7, 2008 | 09:44 AM
WolfPack's Avatar
The only tricky part to doing brakes is if a shop did it before you, its probably wayyy to tight for you to get off. Gotta put some extra mustard on a long armed socket, then you can pop the calipers off!
khunba
LR4
Apr 3, 2014 09:10 PM
iceteacy
Feb 10, 2011 07:27 AM
dragan
Mar 3, 2009 08:19 PM
ljdiscovery
Jan 17, 2009 01:35 PM
ECL
May 7, 2007 01:06 PM
