How to turn on the lockers ?
Old Feb 10, 2015 | 09:04 AM
Jean Filion's Avatar
Default How to turn on the lockers ?
Hello all,
I am ashamed of myself to ask this question, but I can't for the life of me figure out this diagram. lol.
So, I put it in drive (automatic) and move slowly forward, then I stick it in Neutral (automatic), then I manually thrust the Lo Gear Stick Shift forward, put the automatic shifter into D (or 3,2,1). But are the lockers on? Can the stick move to the left? What's with the dotted vs solid lines?
Jean
Old Feb 10, 2015 | 09:18 AM
ZGPhoto's Avatar
There is only one locker, it's the center diff lock.
Move the lever to the left, unless it's frozen.
Old Feb 10, 2015 | 09:52 AM
abran's Avatar
Hi Jean,
If not mistaken you have a 2003, which does not have a locking transfer case. 99'-6/2001 came with a locking transfer case but no shifter to actuate it(many people buy D1 shifter and attach). After 6/2001 through 2003 did not have a locking transfer case. 2004 came with the locking case and a cable actuated shifter which was a 1 year only item.
Unless your Canadian version is different, you will need to source a locking t case and shifter to install.
Old Feb 10, 2015 | 10:10 AM
jafir's Avatar
It's definitely got the correct sticker for the CDL...
Old Feb 10, 2015 | 11:07 AM
schwaggy's Avatar
Yes but... It was a widely known error for the 2003 to have the incorrect sticker. I think there was even a TSB about it.
I've had 2 2003's that had the sticker but no CDL
Old Feb 10, 2015 | 11:38 AM
abran's Avatar
What a let down!
Old Feb 10, 2015 | 05:11 PM
94svt50's Avatar
Does the shifter **** have the same pattern on it as the label?
Old Feb 11, 2015 | 06:25 AM
Shifter **** inscription only says H - N - L
Old Feb 11, 2015 | 06:32 AM
drowssap's Avatar
Sorry no cdl then
Old Feb 11, 2015 | 02:23 PM
schwaggy's Avatar
Yeah, I forgot to mention. The **** is the telltale giveaway.
skatelove303
Jun 20, 2009 08:10 PM
Fivespddisco
Member Group And Special Buys
Mar 1, 2009 06:46 PM
roverwoody
Sep 21, 2008 03:57 PM
andrewmcoffin
Apr 11, 2008 07:33 PM
CrimeScene
Jan 30, 2006 06:12 AM
