How to turn off anti theft on 04 disco
Old Jun 23, 2016 | 08:08 AM
Problem at the disco's Avatar
Default How to turn off anti theft on 04 disco
So I have an 04 disco, the remote stopped working while ago and I only use the key to lock and unlock. Went to open the door yesterday and the door lock just spins doesn't work any more. Grrr, After the police opened the door the anti theft went off and disco will not start and anti theft keeps going off. I unhooked the battery to stop it but how can I turn it off for good? The key in the door for three seconds will not work, obviously. Any help would be great.
Old Jun 23, 2016 | 08:53 AM
mollusc's Avatar
What if you repaired the issue with the door lock and then used the key as usual?
Old Jun 23, 2016 | 09:05 AM
yes planning on doing that but would like to drive in to my guy and not incur the $300 towing cost. Just want to know how I can disable it for now. I have just put new H2O pump Radiator, hoses last week. Funds are low.
Old Jun 23, 2016 | 09:55 AM
number9's Avatar
Only one remote? Did you replace battery with known good one? Surely you have but have to ask.
Couple links on probable issue with fixes.
What did you do with your DII today? - Page 314 - Land Rover Forums - Land Rover Enthusiast Forum
https://landroverforums.com/forum/di...nt-work-74889/
Old Jun 23, 2016 | 10:13 AM
Yes both keys work it is the module in the tuck itself that is not working. New batteries in both. :-(
Old Jun 23, 2016 | 10:16 AM
Thanks for the links I will look through :-)
Old Jun 23, 2016 | 07:51 PM
abran's Avatar
There are 2 attachments from your door handle to your door lock actuator.
1- linkage from handle to actuator that unlatches the lock when the door is unlocked.
2- straight pin from door lock cylinder to door lock actuator.
#2 is broken. Remove door panel, peel back plastic, un hook #1.
Locate small torx on door jamb at handle location and remove.
Remove door handle. Look inside with flashlight and you will see a white cross shaped recessed section on the actuator.
Attach battery and remove horn relay on under hood fuse box.
Use a screw driver to turn the white cross on the actuator mimicking the key unlocking the actuator.
Alarm system will be satisfied.
Old Jun 23, 2016 | 07:58 PM
Abran, Thank you so much, I have the door handle removed and that pin with the cross hairs is broken #2 so I will have to replace. do you know how to get that little pin out that holds the non cross hair par out of the lock?
Old Jun 23, 2016 | 08:09 PM
abran's Avatar
There is a roll pin that holds it in. Use a tiny punch to gently it push out. You can fab a replacement out of a nail.
Old Jun 23, 2016 | 08:16 PM
Thanks you again I will try after dinner :-)
