How's your Blower
Old Aug 8, 2019 | 12:18 PM
Davis31052's Avatar
Default How's your Blower
HVAC Blower fan volume, I mean. Mine is very weak even on the highest setting. I've pulled the motor, cleaned the cage, and verified nothing is clogging the intake under the passenger dash. I have an endoscope and looked inside the plenum and all of the vents and can't find a reason for low volume. Any other suggestions or is this just inherent to the truck?
TIA
-eddie
Old Aug 8, 2019 | 12:30 PM
Richard Gallant's Avatar
I find mine to be quite variable, but is there not a resistor that controls the fan speed ?
Old Aug 8, 2019 | 12:37 PM
Best4x4's Avatar
Seals on the blower pack/flaps.
Old Aug 8, 2019 | 12:40 PM
Davis31052's Avatar
I have all speeds, just no volume. Best4x4, do you know of a seal kit number?
Old Aug 8, 2019 | 01:18 PM
Best4x4's Avatar
No I don’t think LR has a kit for it. I’ve seen them re-sealed with door/window foam with a sticky back on it. If you place your hand up by the windshield I guarantee you’ll feel cold air = leaky blower seals/flaps.
Old Aug 8, 2019 | 01:49 PM
Davis31052's Avatar
yup. cold air out the defrost vents. time to break out the rave manual and pull the dash?
Old Aug 8, 2019 | 02:02 PM
Best4x4's Avatar
To seal everything yep pretty much.
Old Aug 8, 2019 | 07:09 PM
Extinct's Avatar
I think you can get to most of it just by pulling the center stack. Factory never sealed it 100%, so you won't get it sealed back 100%
Old Aug 8, 2019 | 09:23 PM
Ben Matheson's Avatar
Keep in mind the defrost vent flaps have holes so there is always some air going through the defrost outlets
Old Aug 8, 2019 | 10:20 PM
redwhitekat's Avatar
TIA
-eddie
Doesn’t the air enter via that filter mesh media in the hood area ? Check that area. Or maybe try a junk yard blower motor
jamestfl
Apr 28, 2018 07:32 AM
mirepoixmatt
Jun 19, 2016 02:02 PM
russburcham
Mar 27, 2012 10:35 PM
phidelt583
Dec 29, 2010 11:04 PM
alexis524
Apr 1, 2009 08:20 PM
