Hub Replacement
Old Oct 31, 2016 | 09:46 AM
redrover75's Avatar
Default Hub Replacement
If I have a bad hub, makes noise above 60mph. How do I know which side?
The noise is there going straight and goes away when I go slightly right.
Is that the left hub? They do not feel any differently.
Thanks,
Old Oct 31, 2016 | 10:04 AM
coors's Avatar
Thanks,
Your logic make sense. Load transfers from side to side lessens resistance on the "free floating" side.
Can you rule it out by lifting the wheels and checking for play in each respective wheel? Grab firmly at 12 and 6 and check for play in the bearing.
Also, try spinning the wheels freely - monitor for an increase in resistance between the two wheels.
Old Oct 31, 2016 | 10:05 AM
The Deputy's Avatar
Sounds like it would be the left side, if turning to the right quiets it down. Your basically loading the bearing and taking out the slop. I like to remove the wheel and brake caliper, and then spin the hub...listening for grinding or feeling for rough motion, or rock the hub from side to side and pull the outer part of the hub outward...looking for movement.
Personally, I like to place both hubs at once...since I have the tools out and all.
Brian.
Old Oct 31, 2016 | 08:55 PM
Charlie_V's Avatar
Brian.
I agree with Brian. Both at once. Actually, I'd replace all four at once (and have done so myself).
LADEROUTE
Dec 29, 2013 07:22 PM
2Discos
Jul 6, 2013 01:22 PM
LRD2&ME
Apr 19, 2011 02:42 PM
tbesselman
Feb 22, 2010 02:41 PM
mattyh007
Sep 17, 2009 02:07 PM
