Humming at 3000 RPM
Old Jul 20, 2015 | 10:20 AM
the420star's Avatar
Default Humming at 3000 RPM
I just picked up a 1999 discovery 2 in kinversand - 44k miles. FL car, stored indoors.
The car did great on my drive to CT from FL except for one issue.
When the car gets up to about 80mph or 3000 RPM on the tach. I get a humming noise when the car is under load. So if the car is accelerating or "braking" under cruise I get the humming noise.
I tried this again last night by putting the car into second gear and bringing the car up to 3000 RPM - and i get the humming again when under load.
I don't hear this nose any other time, than when i have the engine up at 3000 RPM. I am not sure if this is a propshaft issue or something simpler.
Any advice or checks you can suggest would be greatly appreciated.
Attached Thumbnails Humming at 3000 RPM-%5Efce3f79324945cc9d16a9462f76fbdb0d027b9828897fe6a97%5Epimgpsh_fullsize_distr.jpg
Old Jul 20, 2015 | 11:14 AM
dusty1's Avatar
Would check out shaft
Kind of sounds like bearing noise.
You could test half of the driveline at time by removing a driveshaft and locking your center differential. You wouldn't be able to see if you are getting it in front wheel drive or rear wheel drive or both
Old Jul 20, 2015 | 12:18 PM
the420star's Avatar
How do i lock the center differential? I see references to this - but dont see a way to do it in the truck?
Old Jul 20, 2015 | 02:11 PM
Motorhead1's Avatar
Search the forum for "CDL"...You will learn what it's about.
Old Jul 20, 2015 | 03:57 PM
Frank4's Avatar
3k? Am I the only one that won't push my Discovery past 2100 or so RPM? Mine is in good working order but I would be terrified to run at 3K.
Old Jul 20, 2015 | 04:25 PM
BackInA88's Avatar
The RPM of the drive shaft in 2nd gear at 3000 RPM is a lot slower than when it is in Drive.
Sounds like something attached to the engine alternator, power steering pump?
Old Jul 20, 2015 | 04:26 PM
Alex_M's Avatar
It's actually good for it once in a while. Cleans out carbon deposits and the like. I've been driving the last 20k pedal to the floor from almost every stop light to no ill effects. Of course, that's very excessive just to keep it clean, but I really like to listen to it roar and I've got a bit of a lead foot. Still, it hasn't caused me any problems.
Old Jul 21, 2015 | 06:48 PM
disc oh no's Avatar
Does it have the same hum if you're in neutral and hold a steady 3k rpm?
Unlicky12
Oct 9, 2013 07:56 PM
blkblkrover
Jun 16, 2011 08:35 PM
sebasss
Feb 11, 2010 06:48 AM
rchrds
Aug 4, 2005 01:45 AM
cfrost
Jul 6, 2005 09:58 PM
