Sponsored by: CARiD
tranny shifts hard at 3000 rpm limp mode
Old Oct 9, 2013 | 07:56 PM
Unlicky12's Avatar
3rd Gear
Default tranny shifts hard at 3000 rpm limp mode
ok I have a 2001 lr2 with about 61k on her I'm have tranny issues only code I get is p0722
here is what she is doing from 1st to 2nd shifts hard at 3000 plus rpm after the hard shift a few seconds later limp mode with the m+s and d flashing this happen weather the car Is hot or cold up or down hill as soon as she shifts from 1 to 2 bam limp mode
ok so here is what I done multiply times
cried like little girl
new correct battery
alt charging at right specks
all fuses checked and cleaned
xyz switch changed
tranny filter changed and filled full while car is running blah blah blah
new MAF bosh with frame filter
checked the kick down cable and its fine adjusted it to the manual specs
checked all wires and checked for corrosion
tried unplugging battery to rest ecu left it unplugged for a day with key in on position
checked tire psi all at 40
placed car in reverse with wipes on rear wiper and it came on
all gears light up on dash with shifter ok
other problem cars had or has over heated changed thermostat bleed out air has temp oil light for trans is on little red light in top right conner stays on when first starts up on a cold start or hot Basicly always on air ride system can is busted so rear doesn't fill up that little light is on too saying its *** is down and the key doesn't work on the doors
in short helppppp what do I do next
freeski27
Jan 7, 2014 11:57 AM
sebasss
Feb 11, 2010 06:48 AM
freeland02
Engine & Internal
Nov 25, 2007 04:44 PM
freeland02
Freelander
Sep 27, 2007 10:15 PM
