Humming
Old Feb 1, 2011 | 09:48 AM
jrm123180's Avatar
Default Humming
Hello!
I went to the garage a few months ago and they found that I need an upper ball joint on the drivers side. I just ordered the upper and lower so that I can replace them and get this take care of. My question is, I notices a humming that takes place when taking a right turn. I know that a bad bearing can do this, but will the upper ball joint do it as it gets worse? It makes sense to me as when you take a right turn there is more pressure on the upper ball joint.
Thanks for your help and i hope I included all the information you need to answer this.
STeve
Old Feb 1, 2011 | 10:47 AM
Ball joints have no way of making a humming sound so it is either a cv joint starting to talk to you or a bad hub.
Old Feb 5, 2011 | 12:03 PM
jrm123180's Avatar
Thanks for your response...guess I have to check that bearing now....stupid things are so expensive.
Jerover
Jun 2, 2009 05:05 PM
gmutis
Jan 6, 2009 04:30 PM
IanHand
May 9, 2008 09:18 AM
RamblingMan
Jan 23, 2008 11:49 PM
newBrover
Oct 30, 2006 11:57 AM
