I disconnected my battery and replaced my ignition switch. Once I hooked everything back up, the HVAC will not power back on. Also, the mirrors will no longer adjust. Everything else seems to be working.
I replaced the HVAC panel with a spare I have, and no power to it either. I checked all the fuses & relays on both fuse panels.
My guess is somehow one of the fuse boxes got fried.
OLD POST! But to anyone who is having this problem! I figured it out! Take the plastic off that surrounds the ignition switch barrel. Check on the opposite side of where you insert your key. There will be like 5 wires soldered onto a plastic piece. your issue might be here. I noticed i had a hair line crack in the plastic and when the key was being turned that piece would move. Im assuming inside is a bunch of connections and when the key is turned the power mirrors and A/C control think the car is off and are not receiving power. I was able to get a piece of wire and then also zip tie that piece so that it stays firmly in place until i can get a replacement. But power mirrors and A/C control now work perfectly.
