HVAC panel not getting power
Old Dec 31, 2016 | 11:39 AM
nickm347's Avatar
Default HVAC panel not getting power
'02 4.0SE 110k miles
I disconnected my battery and replaced my ignition switch. Once I hooked everything back up, the HVAC will not power back on. Also, the mirrors will no longer adjust. Everything else seems to be working.
I replaced the HVAC panel with a spare I have, and no power to it either. I checked all the fuses & relays on both fuse panels.
My guess is somehow one of the fuse boxes got fried.
Anyone have an experience with this problem?
Old Dec 31, 2016 | 12:08 PM
abran's Avatar
Probably your interior fuse box. Check to see if you have power coming out of it. There are some built in relays that go bad.
Old Jun 23, 2022 | 05:45 PM
fieldeffectt's Avatar
7th Gear
OLD POST! But to anyone who is having this problem! I figured it out! Take the plastic off that surrounds the ignition switch barrel. Check on the opposite side of where you insert your key. There will be like 5 wires soldered onto a plastic piece. your issue might be here. I noticed i had a hair line crack in the plastic and when the key was being turned that piece would move. Im assuming inside is a bunch of connections and when the key is turned the power mirrors and A/C control think the car is off and are not receiving power. I was able to get a piece of wire and then also zip tie that piece so that it stays firmly in place until i can get a replacement. But power mirrors and A/C control now work perfectly.
fieldeffectt
Apr 12, 2022 07:32 PM
tony1
Nov 17, 2019 09:48 AM
robdis96
Mar 26, 2016 10:15 PM
Beaulim
Sep 26, 2015 09:27 AM
cipher982
May 20, 2011 09:54 PM
