HVAC Question
Old Sep 29, 2015 | 06:45 AM
redrover75's Avatar
Default HVAC Question
When the HVAC is completely off, I get very warm air blowing into the cabin from the defroster vents at the top of the dash.
Is that normal? In past vehicles that usually indiacted that the heater core was failing.
Does anyone have a comment or suggestion?
Thanks,
Old Sep 29, 2015 | 08:39 AM
rtonder's Avatar
Coolant flows through the core constantly, so it remains hot regardless of settings. If the blend flaps are open, along with the main inlet flap, you will get hot air. Could be the inlet flap is hanging up on the linkage. If it happens only at highway speed, it could be drawing through by the slight pressure reduction created inside by the exhaust flaps in the rear of the truck. My two bits.
Old Sep 29, 2015 | 09:04 AM
cappedup's Avatar
That would be my guess. It's more likely a blend door issue.
Read the RAVE section about it.
d4stir
Sep 29, 2015 09:00 AM
comleader
Jul 9, 2013 06:24 AM
blast20
Jan 10, 2010 07:05 AM
ScottinNJ
Oct 28, 2007 09:02 AM
distributorguy
Jul 8, 2007 03:59 PM
