I got a code reader need help with codes
Old May 7, 2012 | 02:43 PM
Draayer's Avatar
Default I got a code reader need help with codes
I have the three amigos lights and got a code reader today, this is what it said, now what do I need to do to fix it?
Thanks,
1.--Current Faults---->
Active Faults:
067:Rear Right sensor electric fail
Logged Faults:
<-END Faults
..--Previous Faults--->
Active Faults:
Logged Faults:
066:Front Left sensor electric fail
<-END Faults
Active Faults:
114:Shuttle Valve Electric Failure
Logged Faults:
<-END Faults
Old May 7, 2012 | 03:55 PM
see http://www.rswsolutions.com/index.ph...d=38&Itemid=65
Old May 7, 2012 | 06:21 PM
Draayer's Avatar
Thanks for the link to the codes.
I assume the codes that say "previous faults" are problems from the past that are fixed and the codes that say "current faults" still need to be fixed, is that correct?
Thanks
Old May 7, 2012 | 06:46 PM
jafir's Avatar
Thanks
Previous faults could be intermittent problems. The 114, shuttle valve switch codes will almost certainly come back. There is a sticky with a link to landroverclubvi that has instructions on how to bypass some flaky wiring or boards.
Old May 7, 2012 | 10:29 PM
Draayer's Avatar
Default How to fix the speed sensor and shuttle valve
I have looked in the Rave manual and did a search on here and have not been able to find info on the speed sensor. Are these a replace type fix, or clean them up or something else? Where are they located and what do they do? I climbed under the rover on the right rear side (thats where the 067 code says the problem is) and there is the wire going into the back of the wheel and going up, the wire goes into a unit about the size of long AA battery. So bottom line, how do I fix this?
Also as for the previous shuttle valve fault, is that fixed by doing the ABS repair that there is a sticky on?
Thanks,
Old May 8, 2012 | 04:35 AM
see https://landroverforums.com/forum/di...sensor+replace
The RAVE shows the ABS wheel sensors as fitted with the hub, but they are sold separately - see Land Rover Parts, Accessories and Information
Old May 8, 2012 | 07:17 AM
thebloody's Avatar
Also when fixing it you have two options, replace just the shuttle valve unit or replace both the unit and the seals. I suggest doing both if you have never replaced the seals because they will go bad eventually and then you are going back to fix them like I am. I did my valve unit because I didn't want to have to bleed the breaks again but here I am having to go back anyway.
Just my two cents.
Old May 8, 2012 | 08:43 AM
Draayer's Avatar
Default Thanks for the replies
If I fix the problems will the amigo lights turn off or do I need the code reader to clear them? I borrowed the code reader from Don (thanks) and need to get that back to him so others can use it.
Old May 8, 2012 | 09:25 AM
jafir's Avatar
Do the lights go off when you first start the car, and then come back after a while of driving? If so, good chance they will go away on their own when you fix the problem. If they are on immediately, your chances go down a lot... but it still COULD, MAYBE be that they will go away when you fix the issue. Some codes may have to be cleared with the scanner to get the light to go off.
Old May 8, 2012 | 09:27 AM
jafir's Avatar
Just my two cents.
Agreed. When I finally did mine, I replaced the seals and the switches... even though my switches tested OK. I wanted to make sure that I wouldn't have to go in again. For the $100 or so in parts, it's a much cheaper fix than the modulator assembly that the dealer would sell you to fix the same problem.
