I have the axle off...do I need to replace these seals?
seal puller? pry out with a screw driver?
Don't scratch the seal seat!
Always pull seals with the pulling device under the 'top' or high position of the seal so that if you do scratch the seal seat, it is at a clock position that is least likely to leak....
I have found that none of the OEM seals are hard to get out. In fact, they have all come out maybe too easily.... Sometimes a touch of hylosil (or appropriate sealant) around the seal 'ring to seat' is needed.....
