I have the axle off...do I need to replace these seals?
Old Jul 23, 2020 | 11:34 AM
Brandon318's Avatar
Default I have the axle off...do I need to replace these seals?
So I have the whole front end apart for an overhaul and wondering if I should replace these axle seals even though they aren’t leaking. Only have 80k on them.
Old Jul 23, 2020 | 11:38 AM
XRAD's Avatar
depends...are they 20 yrs old or have been damaged when you took out the axles?
Old Jul 23, 2020 | 12:02 PM
XRAD's Avatar
and PS: they look to be properly inserted!
Old Jul 23, 2020 | 12:45 PM
frostythor's Avatar
Well to be honest you would be silly not to having done so much, and you will not be a happy bunny if you dont replace them and they leak!!!!
Old Jul 23, 2020 | 12:52 PM
Brandon318's Avatar
It’s the axle from my 2004, so they’re original, but I damaged. I have these spares on hand, but they look quite different from the OE ones.
Old Jul 23, 2020 | 06:13 PM
XRAD's Avatar
those look like the right seals. spring faces inside.....mine have a slightly bigger dust seal (which faces outside)....
Old Jul 23, 2020 | 10:08 PM
Brandon318's Avatar
Perfect, thanks! Best way to remove the old seals?
Old Jul 24, 2020 | 11:27 AM
XRAD's Avatar
seal puller? pry out with a screw driver?
Don't scratch the seal seat!
Always pull seals with the pulling device under the 'top' or high position of the seal so that if you do scratch the seal seat, it is at a clock position that is least likely to leak....
I have found that none of the OEM seals are hard to get out. In fact, they have all come out maybe too easily.... Sometimes a touch of hylosil (or appropriate sealant) around the seal 'ring to seat' is needed.....
winx
Aug 23, 2023 04:22 PM
MacRoadie
Jun 19, 2018 03:40 PM
NiteTrain
Aug 27, 2010 07:57 PM
kymike
Apr 24, 2009 01:17 PM
ajh
Aug 8, 2007 09:22 PM
