I have the oil pan off, do I have to replace cruciform seals?
Old Jul 27, 2021 | 10:53 AM
Brandon318's Avatar
Default I have the oil pan off, do I have to replace cruciform seals?
I thought I had an extra set of new ones but for the life of me can’t find them. I don’t know if they’re leaking or not, and I’m sort of wanting to just wrap this project up instead of waiting another week for new seals… Is it just assumed that they’re always needing replacement if they oil pan gasket is being replaced? The pan gasket was leaking so badly, I have no idea if the cruciforms were or not.
Old Jul 27, 2021 | 11:48 AM
mollusc's Avatar
I have never bothered replacing them when I've had the oil pan off, figuring that I would be tempting fate to mess with them. I know that mine weren't leaking though.
Old Jul 27, 2021 | 12:26 PM
Tony Luna's Avatar
I can say I have successfully replaced the cruciform seals with the engine in the truck - when I replaced the main and rod bearings - big job. I did get the full cross seals from Rimmer Bros. She's been relatively dry since (a couple of years ago). Additionally, I just installed new cruciform seals in my new short block - much easier on an engine stand...
Old Jul 27, 2021 | 03:07 PM
Extinct's Avatar
Not required and unless it was a known leak I would not touch them. The rear main CANNOT leak, I did a post on why. I have two engines recently pulled were the rear cam plug was leaking. Since it is directly over the crank you can imagine it looks just like a rear main or crucifix seal leak. If it was me and leak free was important I would do it, but the probability it is the crucifix seal leaking is less than 50%.
erick846
Dec 1, 2015 11:19 AM
chaz614
Aug 6, 2012 08:35 AM
ngarover
Apr 16, 2012 09:48 PM
shonuff93
Oct 6, 2009 06:22 AM
kean
Feb 24, 2009 03:41 AM
