I killed my Disco, Tray Mtn GA.
Old Mar 27, 2019 | 01:33 PM
  #21
Best4x4's Avatar
If the Fill Plug is starting to look stripped I'd honestly remove the E-Brake Assembly, then pound in the 1/2 extension and break it free. It's not that hard to remove the E-Brake assembly. You just remove the drive shaft, use a manual impact driver to loosen the #3 Phillips Head screw holding the drum into place, pop off the drum, and then inside you'll find 4 15MM bolts securing the assembly to the TC. Once those are loose you can pivot it out of the way and get to the fill plug without any trouble.
Then when you re-install the fill plug don't go crazy tight with it for next time. I have 1 1/2 extension that is slightly shorter than the usual 1/2 extension and it fits perfectly without removing the E-Brake Assembly.
Old May 29, 2019 | 08:02 AM
  #22
back9sunday's Avatar
Disco is back in action!
I had to succumb to taking her to a shop to do the transfer case pull and repair, and they also found a overly worn front diff that needed replacing (no more clunks/jerks from my drivetrain).
Old May 29, 2019 | 09:07 AM
  #23
jastutte's Avatar
nothing wrong with that. i work on mine as time and skill allows but never hesitate to let the pro's work on it when i need to.
and glad you're back on the road.
Old May 29, 2019 | 01:20 PM
  #24
When do you want to go break it again? Thinking of giving the traverse a go myself
Old May 31, 2019 | 10:24 AM
  #25
Much appreciated! I am too. I think I'll wait to tackle Tray Mtn. Need some skid plates, larger tires, and more skilled driving before I conquer that. Hah.
Old May 31, 2019 | 07:32 PM
  #26
XRAD's Avatar
Glad to hear you are back together again. Seriously , you are really lucky to have this in your backyard!!
https://www.georgiaoverland.com/georgiatraverse.html
samsax100
Jan 13, 2015 12:07 PM
Ghostsoldier
Apr 6, 2014 07:50 PM
exquizit23
Jun 5, 2008 02:56 PM
Elskunk
Feb 11, 2008 12:55 AM
riebs
Nov 14, 2006 04:50 PM
