I like the way u guys roll
Old Jul 28, 2008 | 01:11 PM
redhotbuzz's Avatar
Default I like the way u guys roll
Hello All ..........Thanks to you I have been able to turn my 1997 D1 LSE into a real ride...I'm going to replace my manifold -pipe gaskets.. The book says gasket sealer ... should I ?and if yes which kind ?.. Thanks Otto
Old Jul 28, 2008 | 01:27 PM
NiteTrain's Avatar
Default RE: I like the way u guys roll
why not just replace with another gasket?
Old Jul 28, 2008 | 01:34 PM
okdiscoguy's Avatar
If you are talking about your exhaust manifold to downpipe connection, it is a gasket. You can get a new one from atlantic british, or the dealer. Do not use sealant...
Old Jul 28, 2008 | 01:35 PM
redhotbuzz's Avatar
I have the gaskets........ Do I need some kind of sealer??
Old Jul 28, 2008 | 01:44 PM
redhotbuzz's Avatar
After the work Ive done on this truck'Thanks to you guys' AB knows my CC# by heart ,,,,,,,,,Ive replaced the entire front brakeline..
Old Jul 28, 2008 | 02:35 PM
99LRDisc's Avatar
AB is great, but just remeber, Roverlandparts is just as good for used more expensive parts. i saved big on my Trans Cooler
Old Jul 28, 2008 | 02:37 PM
99LRDisc's Avatar
what did you go with for the brake line. Next pay check i'm going all out, ecb brakes rotor and pads all round, and stainless steel braided brake line. Needed muchly on my truck. i just wont be going anywhere at high speed till then
Old Jul 28, 2008 | 03:30 PM
NiteTrain's Avatar
ORIGINAL: redhotbuzz
just the gasket should be fine.
drdabbles
Aug 17, 2010 07:37 PM
gsxrgessler
Jan 26, 2008 08:34 PM
MRDM1
Mar 16, 2007 07:03 PM
Brad S1
Oct 5, 2006 06:51 PM
2k2wranglerx
Mar 12, 2006 06:44 PM
