I need help
Old Sep 28, 2011 | 08:27 PM
Sduquez's Avatar
Default I need help
I have a 2000 land rover 2, 4, 6, 8 is not firing I have change the wires and coilpack and it's still the same. Any idea where to start
Old Sep 28, 2011 | 08:50 PM
jafir's Avatar
No spark at all or are you getting misfires on all of the even cylinders?
Old Sep 28, 2011 | 10:25 PM
One of the two spark (ignition) coils could be unplugged or bad. Here are electric values to test coils.
From the RAVE tech manual:
Input/Output
Input to the low tension side of the ignition coils comes from Fuse 14 located in the passenger compartment fuse box.
This fuse provides battery power for two ignition coils.
It is possible to test both primary and secondary coils of the ignition coils for resistance using a multimeter as follows:
l
Expected primary coil resistance: 0.5 } 0.05 Ω at 20 °C (68 °F).
l
Expected secondary coil resistance: 13.3 } 1.3 kΩ at 20 °C (68 °F).
The ECM provides the earth control for each coil on separate pins as follows:
LH Bank (cylinders 1, 3, 5, 7)
l
Cylinder 1 - pin 6 of connector C0638 of the ECM multiplug.
l
Cylinder 3 - pin 2 of connector C0638 of the ECM multiplug.
l
Cylinder 5 - pin 8 of connector C0638 of the ECM multiplug.
l
Cylinder 7 - pin 7 of connector C0638 of the ECM multiplug.
RH Bank (cylinders 2, 4, 6, 8)
l
Cylinder 2 - pin 2 of connector C0638 of the ECM multiplug.
l
Cylinder 4 - pin 7 of connector C0638 of the ECM multiplug.
l
Cylinder 6 - pin 6 of connector C0638 of the ECM multiplug.
l
Cylinder 8 - pin 8 of connector C0638 of the ECM multiplug.
The ignition coil can fail the following ways or supply incorrect signal:
l
Coil open circuit.
l
Short circuit to vehicle supply.
l
Short circuit to vehicle earth.
l
Faulty component.
In the event of ignition coil failure any of the following symptoms may be observed:
l
Engine misfire on specific cylinders.
l Engine will not start.
Old Sep 29, 2011 | 08:59 AM
Let's don't guess, how do you know they are not firing, what are the fault code numbers and be specific?
In the mean time, quit throw parts at it.
ScreamingLife
Apr 25, 2013 08:32 PM
MuddMouth
Oct 18, 2010 03:01 PM
striversrowatl
May 1, 2010 11:20 AM
Speed racer
Oct 11, 2008 10:56 PM
