I picked up a deal…..
Old Dec 24, 2023 | 01:08 AM
Disco Dad's Avatar
Default I picked up a deal…..
I found a 2001 D2, Alveston red about a week ago. The seller said it needs a new engine. Their “mechanic” threw new coil packs, plugs, and wires at it and came to the conclusion that it needs a new engine. It’s throwing a misfire code for cylinder 5. It appears to have spark. At idle it’s a little rough and when I drove it 100 yards from the house the cleared code comes back and starts flashing. Next step is a compression test. If that’s good, I’m thinking it’s an injector running wide open and dumping fuel. No coolant in the oil. I’ll keep updating as I go. I’ll probably relocate the coils while I’m at it.
Old Dec 24, 2023 | 01:32 AM
longtallsally's Avatar
Alveston is a great color. This is mine when I picked it up. I’ve changed A LOT since then, but it’s been overall a great machine.
On your engine if you can get it to run long enough, try the exhaust gas test and I bet that will tell you if the block is cracked or just needs head gaskets.
Be patient, have fun, and enjoy the ride.
Old Dec 24, 2023 | 10:07 AM
PickleRick's Avatar
If compression is below about 95 psi it will throw a missfire on the afflicted cylinder. I've had it happen from a failed head gasket allowing compression to escape. You could hear the pfffttt sound on that side of the engine (rare).
Had it again from a valve that wasn't seating properly due to carbon build up. Did a valve job and back at it.
Old Dec 24, 2023 | 11:06 AM
Disco Dad's Avatar
Thankfully, this isn’t my first rodeo. I bought my first D1 16 years ago. I’ve bought several over the last 14 years on the cheap to fix and sell. My current white gold D2 “Broomhilda” was a daily for 10 years and was my work van the first year I opened my electric contracting company (6 yrs ago). This is the first since then due to availability (time). Child #3 is 14 and this one will be his. #1 has my original.
Old Dec 24, 2023 | 01:21 PM
miron's Avatar
If you ever make it down to north beacon hill, hit me up, it's always great to meet another disco fanatic (and i also just started restoring one that sat for 10 yeras)
Old Dec 30, 2023 | 07:13 PM
Disco Dad's Avatar
Soooo…… cylinder #5 has 0 compression and I have little metal chunks on top of the piston. My assumption is I have a broken valve/seat. The pic is from my endoscope. I am hoping the worst is having to replace the head. The boy is excited to dig into this. Luckily, we both see this as an adventure.
Old Dec 30, 2023 | 07:25 PM
miron's Avatar
Did your boroscope come with a little mirror attachment? If yes, then you should be able to sort of look up and check the valves.
Old Dec 30, 2023 | 08:05 PM
Disco Dad's Avatar
I wish it did. It would be nice to know but won’t matter. The head is definitely coming off at this point.
Old Jan 1, 2024 | 11:10 AM
Harvlr's Avatar
Seeing this as an adventure is the right attitude. Enjoy it and keep us posted.
Old Jan 1, 2024 | 03:15 PM
Disco Dad's Avatar
I definitely will! I’ve lurked on here for years and have learned so much. The only time I’ve ever had someone else work on anything was because I physically couldn’t fit my arm in and didn’t want to drop the exhaust.
This project will be on hold for a little while. I don’t want to **** off the wife and start another project without finishing a few around the house.😂
