I took the console out to get to the diff, how far can I go?
I tried doing the under the car lubircant to get my CDL to work but I couldnt. I took out the console and I got to the boot where its rivited. I tore sliced off a little and got to a small plate, I took the small plate off, sprayed the LIQUID WRENCH everywhere including the arms on the right and its a little easier getting into LOW range but still NO DIFF LOCK, can I take the second plate off right where you see the 10mm bolts?
and while I took the console off I decided to refinish the wood trim by the window switches that was all cracked and nasty
I dont know about the bolts.
If I remember right when you take that cover off there will be a soleinoid in there, it goes bad and will not let you shift into CDL.
You can remove it and forget it. Or unplug it, I forget which.
Yes, remove all the old dirty water logge dgrease and then use new grease when you put it back together.
I took the shifter out, is that my problem? This seems like whats stuck since I took it out and it still wont move to the left(DIFF LOCK POSITION), should I just hammer that linkage in towawrds the left, hammer it down or what? Also, what should I do where that bowl of my LIQUID WRENCH ? Should I just bolt te shifter back on like that or empty all the out and re-grease??
Eaglerover22
02-21-2012 04:02 PM
