I want to change the brake fluid, how ?
My truck (01 disco II) as 85000 miles, my brake light with the other 2 are on. the ABS is working. wheni push the brake, the pedal is real soft, to have a better grip I have to pump it once. so I think it's time to change the brake fluid, I checked the pads and rotor and they are fine.
I'm using for my bike ( Kawasaki ZZR 1200) a mighty vac pump to bleed my brake, and intend to use it for the disco too. now should I start from the front wheel and then go back or which way should I do that ?
collin Barrows
08-28-2011 07:13 AM
treant985
12-27-2010 02:51 PM
