I want to change the brake fluid, how ?
Old May 19, 2007 | 12:27 PM
loic's Avatar
Default I want to change the brake fluid, how ?
My truck (01 disco II) as 85000 miles, my brake light with the other 2 are on. the ABS is working. wheni push the brake, the pedal is real soft, to have a better grip I have to pump it once. so I think it's time to change the brake fluid, I checked the pads and rotor and they are fine.
I'm using for my bike ( Kawasaki ZZR 1200) a mighty vac pump to bleed my brake, and intend to use it for the disco too. now should I start from the front wheel and then go back or which way should I do that ?
Old May 19, 2007 | 01:55 PM
Default RE: I want to change the brake fluid, how ?
Empty out the reservoir first and put fresh fluid in, then start with the r/r then the l/r, r/f then l/front and you are done. It may take up to 2 qts. of fluid to bleed out all the old fluid.
Mike
Old May 19, 2007 | 07:16 PM
loic's Avatar
cool ! that's all I needed to know !! thanks !!
Old May 19, 2007 | 08:07 PM
If your barke pedal is that soft, you might want to consider replacing the rubber brake hoses with stanless steel also.
Mike
Athana
Jun 8, 2019 10:23 AM
denverdisco1
Oct 9, 2013 09:16 AM
collin Barrows
Aug 28, 2011 07:13 AM
treant985
Dec 27, 2010 02:51 PM
unstable
May 22, 2008 08:19 AM
