Iacv wire?
Iacv wire?
I don't know if beer was it last night or what but I can't find the wire connecter that goes on the iacv. I had to take off the upper intake due to dropping a bolt that was stuck by the coils. I'm sure it's not under the intake but I can't find the wires? Anyone have an idea or know what harness this goes too so I can find it? Thanks
That wire doesn't really go anyplace (as far as distance from the valve itself). The wire goes from the valve right into the wire harness that sits directly behind it (the wire harness that travels across the top of the firewall). You could have sat the intake manifold on top of the wire.
The connector for the coil pack and the IAC are the same and if the connectors were swapped, the coil connector will drop down below the heads.
2003 Discovery 127 K with high miles service complete.
If you run your hand down that part of the harness (a large part T's off and down behind the engine) you should feel the wire coming out of it (I think it's the only wire that leaves the harness at that point). The wire comes out at about the exact same level as it plugs into the back of the IACV. Shouldn't be too difficult to find. Remember, the wire is only like three inches long, maybe four.
D2 2003
11-07-2017 07:41 AM
elboy0712
12-19-2010 02:48 PM
