Idle air control valve
Old Feb 7, 2009 | 11:13 AM
discoboy's Avatar
Default Idle air control valve
What is the average life span of this unit? The truck just turned 60k, 2003 D2. I have owned it about 5 mos now, did all the 60k items per Mikes recommendations, only difference is I went with NGK Iridiums and 8mm STI wires after I got the truck. Had also replaced both valve cover gaskets, should of went farther as I notice oil starting to leak from the valley area, oh well. Idle seems a little rough, so about 2 mos ago I took out the IAC, cleaned the unit with brake clean because I noticed it was stuck and not moving, started moving after I cleaned it. Could the unit be going bad, or is it normal for these motors to be a little rough?
Old Feb 7, 2009 | 01:11 PM
Default RE: Idle air control valve
Doubtful!!
Why did you take it out and apart, shouldn't have.
Do you have a CEL on, if so what codes?
Have you cleaned the t/body?
Check for vacuum leaks at hoses and around the manifold.
As to your question, they usually don't fail.
Old Feb 7, 2009 | 04:56 PM
discoboy's Avatar
I did not take it apart, I took out the unit and sprayed brake clean to clean it out, the butterfly valve inside was freed after cleaning it. I read about this procedure somewhere, so I tried it. The idle is not that bad, just thought if it would improve with a new valve.
agthird
Dec 22, 2022 12:59 PM
harvy17
Jul 30, 2010 06:00 AM
Suede
Apr 28, 2010 10:07 PM
me3ps
Nov 25, 2009 08:12 PM
bearcatfans
Dec 18, 2007 09:01 PM
