If it's not one thing . . .
Old Apr 24, 2025 | 08:56 PM
DaOnlyHihiNalu's Avatar
7th Gear
Originally Posted by Tony Luna
Thank you! I looked at the link you gave me and we changed the gaskets there but didn't notice any cracks. I'll do a soap test to double check. Thank you for your input!
Old Apr 24, 2025 | 09:13 PM
7th Gear
Originally Posted by whowa004
spark plugs generally don't mean increasing noise. If gasket didn't fix the exhaust leak then the downpipe most likely cracked right at the weld seam underneath the connection from manifold to pipe. Very common failure point. Exhaust shop should be able to get it welded back up at a reasonable cost.
Thank you for your input! I agree with the sound from a spark plug. I've never had a spark plug go out I guess cause that was not the first or last thing that came to my mind when I heard the exhaust leak and the smelling of gas fumes where I didn't have that before (in my opinion) pretty much confirmed exhaust leak to me. Everyone I told that to seemed to think I was wrong and when everyone else says it's something else I doubted my own instinct and went with them. What frosts my windows is that this should have been fixed pretty quickly but instead my Rover has been parked and I've been without it for way too long as well as spent way more money than it should have cost on things that didn't need fixing, not to mention fixing things that got broke along the way that weren't broke from the start.
Old Apr 25, 2025 | 06:59 PM
Windycity_rover's Avatar
If you need to find obsolete or hard to find stuff try one of the wreakers. Will Tillery can be a great source for that linkage bolt. Drop him an email with specifics.
willtillery@roverguy.com
roverguy.com
gulfstream69xr7
Feb 12, 2025 06:00 PM
TripleThreat
Jan 22, 2018 09:47 PM
philhan
Feb 29, 2008 06:24 PM
SpeedAgent
Jul 27, 2007 01:20 PM
ITMagician
Jun 12, 2006 08:37 PM
