Ignition issues
Old Jun 4, 2013 | 08:18 AM
  #41
matt3502's Avatar
Von- I can understand why you are going to the mechanic, it can be a daunting repair if you have not done it. That being said, order the parts yourself to save money. AB has the individual coils, they are $70 each versus the coil pack @ $270. The only other part that you need is the IM gasket. One issue I ran into was that after I did it myself, I was throwing a P0101 code. When I re-connected the throttle and cruise control cable bracket, is was at a slightly different tension, so it change the idle setting. Took a couple of tries, but by using the RPM setting on my UG I was able to adjust the throttle cable and get it to the right RPM. Hope you get it squared away.
Old Jul 3, 2013 | 03:44 PM
  #42
vonrock's Avatar
It was the coil. I replaced them both.
Old Jan 30, 2015 | 06:10 PM
  #43
colson2003's Avatar
help help help no start after wires plugs coils and intake gasket replaced D2
Old Jan 31, 2015 | 07:43 AM
  #44
matt3502's Avatar
Does it turn over at all?
Old Jan 31, 2015 | 09:23 AM
  #45
colson2003's Avatar
yes. Just pulled a plug and found no spark. also swapped the MAF for a known good one from a 2001.
will rocket
Off Topic
Sep 12, 2013 06:23 AM
1998DiscoverySE
Jun 27, 2012 01:56 PM
moneypit37
Nov 27, 2006 02:20 AM
jaxrvr
Apr 24, 2005 12:01 AM
timjescol
Mar 7, 2005 09:16 PM
