Ignition locked after battery disconnection
Old Apr 30, 2019 | 03:02 PM
stefanas's Avatar
Default Ignition locked after battery disconnection
I disconnected my battery to put on new terminal connectors. Time offline was about 2 hours tops.
The ignition turned the engine on once (to test it) and now will not turn at all. I cannot turn or position the key to any position. Totally locked
Lights work, horn works, doors work. Windows DONT. My driver side window is down and I cant raise it.
I tried all the wiggly wheel, gear shift etc first.
Second I read a tremendous amount regarding it may be the immobilizer. I contact Land Rover for the security code for my VIN# and then tried it many times as specified by the RAVE instructions I found in these forums. Unsuccessful.
I don't believe its the immobilizer. When I start the code sequence I start by holding the key in UNLOCK position in the door for 5 seconds (as specified) but I do not get any audiable beep that would suggest the car is now ready to receive the code (that should happen)
Any suggestions of where to go next? I have reconnected and disconnected the battery a few times as well.
-Stefan
Old Apr 30, 2019 | 06:54 PM
Ben Matheson's Avatar
Just a guess but sounds like the ignition switch failed. You can remove it and change ignition position manually
Or give a shot of wd40 into the ignition a shot. Not the best thing to use but might free up a stuck tumbler
Old Apr 30, 2019 | 07:57 PM
stefanas's Avatar
BEN THAT DID THE TRICK! THANK YOU SIR! I thinks I may need to replace a new cylinder then? I dont want this happening again
Old Apr 30, 2019 | 08:15 PM
Glad it worked
Old Apr 30, 2019 | 10:43 PM
mollusc's Avatar
since lubricating the lock worked, you might want to get some graphite grease or other lock-specific substance to keep it operating smoothly. wd-40 doesn't tend to hang around very long.
Old May 1, 2019 | 06:45 AM
lordmorpheus's Avatar
I would recommend powdered graphite. Available almost everywhere and comes in a squeeze tube you can squirt into the cylinder.
Old May 1, 2019 | 03:21 PM
mln01's Avatar
Or you could do this ...
My ignition switch has been funky a few years now, but I consider it another anti-theft feature. If it gets more funky I'll probably do this.
RobsRover
Apr 13, 2019 03:33 AM
fishEH
Sep 7, 2016 11:29 AM
cjumet
Nov 25, 2008 01:29 PM
wesk
Jan 23, 2008 01:55 PM
