Ignition Switch
Old Aug 2, 2018 | 06:17 PM
duscarter's Avatar
Default Ignition Switch
Hi,
I'm a new member that just bought a 2001 D II that needs some work. I've read through most of the stickeys.
I'm in the process of doing the ignition lock fix, but at a stopping point.
What is the trick to get the barrel and the ignition switch to line up? I can't get the switch to stop at 0, so I can get the key out. It looks like the barrel will only go on 4 different ways. I can't get either to work.
Old Aug 4, 2018 | 08:50 AM
aemnky606's Avatar
Make sure your hi/low shifter is fully in hi. Also make sure you are fully in park. Both of these will prevent the me from going to 0.
Old Aug 4, 2018 | 09:10 AM
duscarter's Avatar
Thanks, I got it back on. It goes to 0 but it is so close to the Acc position that I don't think it is right.
Old Sep 10, 2018 | 08:06 AM
hotrod46's Avatar
6th Gear
I have a key that will not turn to 0. the battery goes dead. the key will turn fully on and start the car. we have checked the park but today will check the hi-lo
Shiftonthefly1
Jun 4, 2017 09:34 PM
DoNMayor
Apr 13, 2015 10:00 PM
FLA Rover
Jul 10, 2014 02:39 PM
aivie82
Sep 7, 2009 05:48 PM
wesk
Jan 23, 2008 01:55 PM
