I'm back! And a question on a fix for slipped liners
Old Jun 29, 2017 | 02:28 PM
Spencerfitch's Avatar
Default I'm back! And a question on a fix for slipped liners
So I'm on Land Rover #8 an 03 discovery. I but it fix the cracked exhaust manifold and have a tick when hot, I'm fairly certain it's a liner. No coolant loss, but I'm not starting a thread for diagnosing.
Id like to know why instead of "pinning" the liner, we can't use a little JB weld on it at the bottom of the cylinder......
ideas?
Old Jun 29, 2017 | 02:56 PM
KingKoopa's Avatar
Awesome idea. Try it. Record for our enjoyment.
Old Jun 29, 2017 | 03:20 PM
LR03NJ's Avatar
lol! Are you seeious? Better yet an exhust glue. 🤔
Old Jun 29, 2017 | 03:23 PM
abran's Avatar
More than likely your tick is oil starvation at the top end. Walked cam bearing, cracked oil pump gear, or overall out of tolerance parts.
Try bringing the temps down first, then try using an engine flush.
Old Jun 29, 2017 | 04:14 PM
LR03NJ's Avatar
Just want to throw a question while liners are involved here. Any body knows how much clearance from the piston when its all the way down and to the bottom of the liner? Also, what is the diameter of the piston? Anybody? Thanks
Old Jun 29, 2017 | 04:27 PM
Alex_M's Avatar
JB weld is an epoxy. It doesn't actually weld anything. Essentially a glorified glue. It will end terribly for your engine when it breaks off and jams into something at 3k RPM.
There is an alternative to pinning the liner. That is welding the liner. You still have to drill the same, but them you fill the home with weld instead of inserting a bolt.
Old Jun 29, 2017 | 05:16 PM
number9's Avatar
You can do anything you like. That will not work though.
Old Jun 29, 2017 | 05:37 PM
Ah see this place has never changed. I think I got tired of it years ago since it was nothing but god emporer disco mike, paranoia or trolling every thread.
Old Jun 29, 2017 | 05:50 PM
KingKoopa's Avatar
Speaking of which, where did discomike go?
Old Jun 29, 2017 | 11:04 PM
Alex_M's Avatar
Nobody really knows. He's floated back in for a few days on a couple of occasions, but has pretty much been gone for like three or four years now.
I say good riddance. Don't get me wrong, he was hugely helpful every once in a while, but he was also way too "my way or the highway" when it came to things he disagreed with. And the places he was hugely helpful, we have people that are just as helpful now.
