Im have a problem
Old Sep 23, 2009 | 10:30 PM
James Wallace's Avatar
3rd Gear
ok I will check it tommorrow when I get a chance.
Old Sep 24, 2009 | 10:00 AM
antichrist's Avatar
Originally Posted by okdiscoguy
If he crawls under the truck and locks the transfer case, he will find that he can drive it short distances. With it unlocked, you can jack up the front, being very careful and the parking brake securely set, pop it inot gear and see if the front wheels spin. If they don't, it is the diff. If one spins, it is time to check the axle on the side that doesn't spin. You can pop the cover off the diff and spin each tire to see if it spins back to the diff. This will also allow you to check the front diff.
If he does that, it will drive off the jack. The only safe way to do that with the center diff locked is to put it on jack stands with all 4 wheels off the ground. Or at least one rear and one front, if it doesn't have locking diffs or TC.
But he doesn't need to. He knows he has either a broken front axle or diff. So all he needs to do is put the front end on jack stands and turn one wheel while someone holds the other from turning. If the propshaft turns, that axle is probably ok, unless you hear grinding noises when you're doing it (that could mean the broken pieces have enough contact friction to still make it turn). So he should pull the other axle, because either it or the diff is broken. You have to pull both axles if the diff is broken, so you haven't lost anything by pulling the other axle.
If it were me though, I'd just pull both axles and if one is broken replace them both and keep the "good" one as a spare. If one broke, the other has probably been over stressed, just not enough to break yet. And like I said, you have to pull them both anyway to replace the diff if that turns out to be the problem.
Old Sep 26, 2009 | 01:58 PM
3rd Gear
I jacked it up the front wheels didn't spin I put it in low and they still didn't the part place is closed so I'm just going to let her sit a day or two thank you for all the help!!
clang
Nov 12, 2015 12:17 PM
chriss2s
May 29, 2012 06:51 AM
nelsontod
May 18, 2012 12:20 PM
USMC_Denver
Apr 21, 2009 05:58 PM
