I'm so frustrated. I have aftermarket prop shaft!
Old Sep 5, 2012 | 03:02 PM
Rover De Land's Avatar
Default I'm so frustrated. I have aftermarket prop shaft!
So after removing prop shaft and centering ball and all u joints, I realize! I have an after market prop shaft that uses 1310 u joints and a different dust cover for centering ball...
I have the centering ball already installed.. Minus the dust cover. My trucks also going to be out of commission for another couple days because I don't have a CDL..
And to top it all off the dive shaft was mostly fine and all of this wasted time and money isn't going to solve my vibration.
Old Sep 5, 2012 | 03:10 PM
yloDiscoII's Avatar
That doesn't mean it's aftermarket, just means someone has already rebuilt it right?
If it wasn't balanced, and you balance it, your vibration might be cured...next step will be the rear.
Old Sep 5, 2012 | 04:27 PM
Nope I uses 1310 series parts..
Old Sep 5, 2012 | 06:38 PM
Banzai Jimmy's Avatar
Wouldn't hurt to have a shop check the balance on it. Never know what they may find.
I have a TW DC shaft on the front that needed the centering ball replaced. Not feeling adventuresome that day (have done many in the past), I took it to a shop. Turns out the tube was bent - but not enough to notice when looking at it. Granted, I push mine offroad so it wasn't a total surprise. But, I don't have a set of blocks to roll it on or a lathe to put it on to check for straightness - it's something I would not have caught.
Old Sep 5, 2012 | 07:07 PM
I hear ya, but when I bought it had a vibration. The shop said they didn't think it was the driveshaft because they swapped it out with another dII on the lot. So this one came from that one.. Chances are it wasn't the driveshaft. Not to mention everything looked great.
Old Sep 5, 2012 | 07:17 PM
lr2001silver's Avatar
Banned
The key word there is """think""" you can think all you want but unless you go get it checked you dont know for a fact. Your cheapest option would be to get it balanced or you could do it backwards and start with the high dollar parts first, its your money.
Old Sep 6, 2012 | 02:34 AM
Oh I forgot to mention, after this it's going to a shop on a lift to be checked
Alex_M
Sep 7, 2024 05:21 PM
jrm123180
Aug 15, 2010 05:23 PM
ALEXAN
Sep 28, 2009 11:33 AM
drzjoint
Aug 6, 2009 11:49 AM
ajh
Aug 22, 2007 05:30 PM
