Im STUCK in MUD! 97 discovery
Old Feb 17, 2009 | 06:01 AM
krispyklene's Avatar
3rd Gear
Default Im STUCK in MUD! 97 discovery
hey guys i'm obviously new to the forums... and just recently i found myself stuck in a big hole.... the it's muddy and it seems that there may be a sandbar like patch of dirt under the front and rear axels keeping me from getting towed out.... the area has no trees... and big bolders... i'm kinda stuck on what to do... any suggestions? i may be able to dig it out... but my friend has tried towing me out to no avail.i tried putting rocks under the tires but nothing... also... it seems like the car may be leaning on the drivers side... cause no matter the position of the DIFF LOCK gear stick, only the slightly elevated passenger side wheels turn.
Old Feb 17, 2009 | 07:09 AM
FALLFORWARD's Avatar
That sucks!!!! How about a crane???? You really got yourself in a bad spot!!!! SOUNDS LIKE SUCTION IS THE PROBLEM. If you can dig the front wheels out on an angle about 8 ft out from the front end, get a buddy with a winch, put 2, 2x8x8ft boards down in front of the front tires. Should do the trick. Its all about finding the right angle!!!!!!!!!!!!
Old Feb 17, 2009 | 08:43 AM
tomfraser's Avatar
a tracktor.... my friends jeep wrangler got stuck up so that the trailer ball was under mud (the jeep was on a 3 inch lift, and 34 inch mud terrains)
we needed a tracktor to get him out
So, first of all, only try to move it while in low lock, not any of the other positins. You will most likely need a heavy rig with a winch or a tow truck.
After getting out, put some decent tires on the truck and learn how to drive it better.
Good luck
Old Feb 17, 2009 | 09:07 AM
Jupiter Rover's Avatar
A F250, 2500, ect will get you out no problem. Just find someone with a big truck, preferably a diesel. Just attach the strap and tug slowly. Every time I have ever been stuck and no one could get me out I just got a guy with a big truck and it came out very easily.
Old Feb 17, 2009 | 09:11 AM
3rd Gear
thanks... does anyone here know if a tow truck can service me and help me? in the area of RIVERSIDE, CA
Old Feb 17, 2009 | 09:17 AM
grussell's Avatar
What would he attach the strap too?
Old Feb 17, 2009 | 10:52 AM
sloppyjoe's Avatar
we need pics
Old Feb 17, 2009 | 01:34 PM
3rd Gear
it's out. thanks
Old Feb 17, 2009 | 01:50 PM
salve7's Avatar
How did you get it out?
Roywilliams14
May 17, 2014 01:27 PM
ImQuattro
May 1, 2014 08:36 PM
Spencerfitch
Dec 17, 2010 10:48 AM
Baylink
Off Topic
Dec 30, 2009 08:31 AM
Kraftyz51
Sep 9, 2007 08:37 AM
