initiating a EVAP leak test
Old Nov 10, 2024 | 08:52 PM
mackendw's Avatar
Default initiating a EVAP leak test
Am getting intermittent P0455 code (SES). D2 with 4.6L...2003 model. 70K on it.
Anyone know if the ECU allows scan tools to initiate the leak test on the vehicle? I'm assuming that this test would
perform a close of the purge vent solenoid before doing the test....
Using an autel 619 scantool. Looking for persons who've gone down this road for pointers.
thx for any insight.
Old Nov 11, 2024 | 08:03 AM
mackendw's Avatar
survey says....no. autel 619 will not allow the EVAP self test to initiate. snikes.
Old Nov 11, 2024 | 10:46 AM
Harvlr's Avatar
What about a smoke test? There are YouTube videos on making your own smoke machine for fairly cheap.
Old Nov 11, 2024 | 10:47 AM
mackendw's Avatar
yep...that is my next course of action. watched a couple of videos on doing the test. do you know how to close the vent solenoid at the
charcoal canister? some scan tools (likely big bucks) can do this....mine no bueno.
would just putting a stopper in the exit hole in the hose end from it do the trick?
Old Nov 11, 2024 | 07:40 PM
redrover75's Avatar
When I have done smoke tests, I take a plastic cover from an old MAF and put a brass fitting through that. I took a harbor freight pump and tapped a cigar to the input and the output to the brass fitting and put the ~4" plastic plug in the maf and pumped away. $10 all in and works great. I am not sure you need to do anything w the solenoids, at least I have not heard of anyone else doing anything w them.
mln01
May 2, 2022 07:59 AM
Chris59
Oct 9, 2020 10:31 AM
s10lowrider1994
May 16, 2013 03:49 PM
jhill15
Jan 6, 2013 08:21 AM
Camdisco24
Apr 13, 2007 07:53 PM
