Installing an Oil Pressuge Gauge on a 2003 Disco II
Old Sep 9, 2010 | 02:12 PM
bosshogt's Avatar
Installed the Cyberdyne Green LED oil pressure guage tonight. Painted the A-Pillars black with Rustolium truck bed liner. They now resemble the dashboard texture. Relocated the driver's side tweeter about 3 inches higher. Heat molded the black guage pod to the A-pillar used some Bondo and caulk to make it look smooth on all parts of the A-Pillar. I think this looks really custom and cool. Digital guage is set to flash if oil pressure falls below 15psi. I am very happy with this mod! iPhone app is named vehical clinometer. Just found another app that shows a Defender. The cockpit just got cooler.
Digital Oil Pressure Gauge Green Black Bezel A010E160Y
Pictures at night: Some more day pictures to come
Last edited by bosshogt; Sep 18, 2010 at 11:57 PM. Reason: Digital guage pictures added.
Old Sep 9, 2010 | 02:38 PM
tito5590805's Avatar
Sticky Please! Nice job on the tap out!
I was lucky I didnt have to wait 3/4 days for the adapter since the guy on ebay was here locally in LA, received my adapter the next day!
Old Sep 9, 2010 | 02:43 PM
Bundu's Avatar
Banned
Originally Posted by bosshogt
Bump this back out front with the OE oil plug tapped to 1\8" NPT
Another cool idea.
Old Sep 9, 2010 | 07:20 PM
jycsalas's Avatar
I love the snow ball effect. Def blows my setup out the water. I like it!
Old Sep 9, 2010 | 07:26 PM
Is the Glowshift gauge a standard size?
I dont like the 17 year old Fast and Furious pod and I would like to use a under the dash kind of mount.
Old Sep 9, 2010 | 11:47 PM
bosshogt's Avatar
Yes Spike those are both 2 1/8" diameter gauges. Like the large display you see behind the counter at Oreilly's. If you remove the A-pillars & paint them flat black and install the black gauge pod it looks very nice and custom. You can even use a heat gun to form the pod perfectly around the pillar. After researching all this stuff for about 2 weeks, I found all A-pillars even in black interior Disco's are all beige(non black). So I painted mine tonight. The A-pillars dont come off without a little fight, but are held on nicely with 3 metal spring clips. I painted them with the left over Rustolium truck bed liner I had from the wheel well project. It adds a nice texture that resembles the dashboard finish.
Old Sep 19, 2010 | 12:05 AM
bosshogt's Avatar
Digital green oil pressure guage option installed scroll up for pictures. Bump out to the front. 2nd Page
Old Dec 10, 2010 | 10:34 AM
Lee97Disco1's Avatar
Default D1?
Will this same original write-up work for a D1? What differences are there?
Old Dec 10, 2010 | 12:19 PM
bosshogt's Avatar
Lee97Disco1,
I think most all should be the same. Although you might have engine oil cooler lines on the front cover in those plugs. I know the 99-2002 Dico II's did. But there still might be a open plug on your DI. You will have to investigate. Otherwise follow the instructions and pictures and let up know if you need some help.
Old Jan 4, 2011 | 12:49 PM
Default Ebay Adaptor Link Update
The original link is not working. Here is a new link: http://cgi.ebay.com/ebaymotors/Senso...item2a0ce0ebfa
when this one goes bad, just look up Seller "authentic-boosting" on ebay.
or do a search for "M20x1.5".
Good luck!
