Installing a Temp Gauge on a 2003 Disco II
Old Apr 15, 2013 | 11:12 AM
  #41
caymandrew's Avatar
great thread, this is next on my list. When cutting the hose, is it free of fluid? I thought there was no air in the system? Should I be prepared for a mess? Thanks!
Old Apr 15, 2013 | 11:38 AM
  #42
04duxlr's Avatar
Yes, there will be a bit of a mess but it's not too bad as the hose you cut is the highest in the system. Just make the cut quickly and put the fitting in. Then you can easily bleed the system because the air will all be at the bleeding tee. Just lift up the reservoir, open the screw and wait until you get a steady flow of coolant and that's it.
Old Apr 15, 2013 | 07:28 PM
  #43
slabrat's Avatar
From everything I have read on this forum,the Dexcool needs to go. I probably wouldn't be putting in head gaskets right now if I had a better coolant gauge. I have one now and will have 2 pretty soon.
Nice looking ride by the way
Old Nov 4, 2013 | 07:52 PM
  #44
FlyingZebra34's Avatar
So I got my oil and water temp gauges installed and they're great but the memory doesn't seem to work and they come up blue every time.
I have them plugged into the same fuse the clock uses (both wires)
Any ideas on how to remedy?
Attached Thumbnails Installing a Temp Gauge on a 2003 Disco II-img_20131015_205854_700.jpg
Old Nov 5, 2013 | 04:28 PM
  #45
OffroadFrance's Avatar
Originally Posted by ShortTom
Tito, GOTTA ask, did you buy your Disco that clean or disassemble everything and put each component through a hot bath?
Very nicely done, though I'd prefer a less intrusive (i.e. no holes) pillar set...I'm not sure the value of adding an aftermarket temp gauge though? I figure the factory one is accurate enough even though I don't know the exact temp.
+1 Superb engine bay - could eat my dinner out of there only it would mess it up.
Old Apr 7, 2016 | 10:27 AM
  #46
0304Disco's Avatar
When you look at the aftermarket gauge reading using this install vs the reading via the ODBII connected to the coolant sensor on the intake manifold there is a lower temp on the aftermarket gauge by at least 10-15 degrees. I don't know the exact flow pattern of the coolant through the hoses but I'm assuming the install shown in this write up is of the coolant back into the engine from the radiator which would make sense as to why it is cooler.
Gromeo
Aug 25, 2015 06:30 AM
tito5590805
Nov 3, 2013 03:29 PM
collin Barrows
Aug 8, 2011 09:33 PM
lipadj46
Feb 16, 2010 05:20 PM
josemex
Sep 18, 2009 06:25 AM
