Instrument Panel not working in 2002 Discovery II
Old Aug 9, 2012 | 08:12 PM
WelderJoe's Avatar
5th Gear
Default Instrument Panel not working in 2002 Discovery II
On the way home from work, cranked up my Discovery and the instrument panel was not working. Gauges were dead.Truck drove fine. Radio, head lights, ac everything else, just gauges are dead. Help
Old Aug 9, 2012 | 08:50 PM
Check fuses 10 & 13 under hood, and 25, 27, 36 under dash.
Old Aug 10, 2012 | 06:01 AM
WelderJoe's Avatar
5th Gear
Default 2002 discovery instrument panel
I checked,could not find fuse 36. Tried the others , instrument cluster still off.
Old Aug 10, 2012 | 07:32 AM
I may have looked at wrong year. Under hood 10 & 14 are involved, under dash 27, 35, 25 are shown. I think 14 under hood runs most of the cluster. The instruments appear to get their ground side at a header which manual shows as under the carpet?? If ground was bad, seems like warning lights would be off as well.
File Type: pdf
Old Aug 10, 2012 | 12:58 PM
WelderJoe's Avatar
5th Gear
Default funny story
Wife's friend owns an import salvage yard. Bought a 2001 instrument cluster for 50 bucks. Wife said I wonder if the fuses you purchased were the wrong type(She sold Jags, rovers, audis and porsches for yrs). Stopped and found some different style fuses than what I had purchased. Tried them out. Dash works... Now I have an xtra instrument panel.. Oh well.. Thanks for your help.. You are great!!!
Old Aug 10, 2012 | 01:12 PM
jafir's Avatar
It's good that the fuses fix it. If you swap the cluster, the odometer will flash until you get the miles synced.
Old Aug 13, 2012 | 10:20 AM
WelderJoe's Avatar
5th Gear
Default instrument cluster not working again
Got into the Disco today. You guessed it, instrument cluster has stopped working again!!!! What to do what to do...
Old Aug 13, 2012 | 10:31 AM
jafir's Avatar
Was it fuses in the under dash fuse box you replaced? That box is known to have issues sometimes.
Old Aug 13, 2012 | 06:57 PM
WelderJoe's Avatar
5th Gear
I tried the ones under the dash and under the hood. I am at a losss. I saw some where that it could be tied in with the parking light?. If the box has issues what should I look for or do.? Hubby works late. This is his wife and have tried to work on it all day ...LOL
Rover505
Mar 14, 2024 11:38 AM
hatanhi
Aug 2, 2013 03:07 PM
jonnymcd
Mar 24, 2007 01:07 AM
litterlout
Aug 27, 2006 11:16 AM
James Vee
Feb 1, 2006 10:34 AM
