Intake manifold
Old Jul 15, 2020 | 01:55 PM
merebel's Avatar
Originally Posted by XRAD
looks like someone was already in there! Missing some bolts...
TIP: to drain coolant BELOW the level of the heads/intake, remove overflow tank cap, remove the tank from mount, then pour out what you can into catch container. Then unclamp and remove lower overflow tank hose (the large one) and hold it below the level of the heads while placing it into catch can (an empty coolant jug works well). Loosen/remove the air bleed screw. This will empty a large portion of top end coolant without making a mess.....
thanks Xrad that sounds like a good idea
and why do you think I have an oil leak up there somewhere lol
Old Jul 15, 2020 | 06:37 PM
Extinct's Avatar
I am going to bet you don't have the PCV mod done, that is why you have oil leak up top. Streatch a latex glove over the oil filler tube with the engine running, there should be slight suction, not pressure. Plugged pcv results in pressure.
Old Jul 15, 2020 | 06:41 PM
merebel's Avatar
pcv mod done I have been chasing oil leaks for awhile.
1st one oil pan missing bolts
had to replace oil pump anyway.
2nd power steering leaking.
3rd oil from top half passengers side behind alternator area.
head gaskets done and looks like they didn’t do all the things needed when putting gaskets in :-(
Old Jul 16, 2020 | 08:54 AM
XRAD's Avatar
topside Oil leak main causes:
PCV as stated above.
valve covers
lower pan RTV as you stated
Old Jul 16, 2020 | 04:30 PM
The Deputy's Avatar
8mm and 5/16 12 pt sockets are the same.
Old Aug 1, 2020 | 07:27 AM
merebel's Avatar
Well finally getting to this today due to family and work a weather.
and have removed the ac unit to the side and looking behind the alternator I see what looks like a lot of oil build up.
took a pic but still to dark in there.
so maybe just that valve cover gasket junk. If so great less to do lol if not I have all the stuff to keep going.
Shryan
Apr 1, 2013 08:53 PM
key421
Sep 20, 2011 09:07 AM
popey
Jan 26, 2011 11:07 PM
oysterhead
Apr 10, 2010 08:06 AM
Bob2003Discovery
Mar 27, 2010 10:33 PM
