Intake manifold replacement
Old Dec 12, 2006 | 11:57 PM
sealluke's Avatar
Default Intake manifold replacement
Hello I am new to the forum. I have had a 96 Disco SE7 for over 4 years and the other day I noticed more oil than normal coming out on the ground than normal. I popped the hood and the intake manifold "valley" gasket had opened in the back part of the engine and was letting the oil out. I ordered the fix: http://www.roverparts.com/Parts/9218.cfm
I see what I am up against in removing all that stuff on top of it. My question is: does any one have a write-up, diagram, pics and some to do's and don'ts on the fix. It looks easy but there's got to be something tricky about the fix. I also noticed the valve cover had a more rounded bolt the the normal hex type. Any advice or pictures would be greatly appreciated.
Old Dec 17, 2006 | 11:58 AM
sealluke's Avatar
Default RE: Intake manifold replacement
I gave it a shot and was able to install a new manifold gasket and valve cover gaskets - it took about 4-6 hours and I have sore knees from perching on the radiator. It's leak free and DONE ready for Winter.
The only tricky thing was to becareful when you put the steel intake nuts back into the alum. block - the angle can mis-thread them. It just takes time and patience and drive.Rediculous -HIGH Labor costs avoided. The gasket kit cost $60-70 at http://www.roverparts.com/
NO MORE LEAKS
jsyonker
Nov 12, 2012 09:15 PM
maxellfullmoon
Jul 26, 2010 09:09 PM
brw1982
Jul 21, 2008 11:42 AM
bal51365
Oct 10, 2007 09:36 AM
jbriggs
Jul 14, 2006 01:07 AM
